OEM Pre LCI M Sport bumper fit on LCI? PDC as well.
Hey guys,
I see threads asking if LCI fits on PreLCI and it says yes, but how about Pre LCI fitting on an LCI? Seller I'm looking at says the PDC holes are 30mm, can't seem to find measurements on LCI size. Are there brackets inside that I should consider for the install? Any help would be great! This is an OEM bumper by the way, no aftermarket. |
You are correct on the (pre) fitting the (lci) but not vice versa... I can not tell you why but I have read this more than once thru the years on the forums.
| All times are GMT -8. The time now is 01:10 AM. |
