Oem mtech bumper fog light fitment
My Ride: BMW 525I MYSTIC BLUE
Engine: standard
I just ordered an OEM Mtech front bumper.. will the factory fogs from my 04 pre-lci fit properly? ...anyone have any experiences or advice..
My Ride: 2008 528i
Will your non-MTech 04' Fogs fit the OEM MTech bumper (assuming pre-LCI)?
I have Pre-LCI fogs in my LCI MTech. I did need to buy a H8 to 9006 wire harness for the foglight connection. The fitment was perfect, with no issues!
I hope this helps.
I hope this helps.
In my case, the 05 530i original bumper fog lights wood not fit, had to order. Also the grill, left & right cover blanks and left & right break vents had to be ordered as well.
Administrator
Who did you order from? I've heard of fitment issues with some vendors. In my case, I ordered my MTech from Trinity Autosport and had no issues reusing my Pre-LCI fogs.
Engine: standard
thanks it helps..i ordered the factory OEM BMW MTECH 04-07 bumper..just wanted to re-use my factory 04 fogs..or find out if i have to upgrade and mess with wiring..
Engine: standard
Thanks.. i decided to go OEM bmw mtech..i have the m5tech aftermarket before and it cracked so just wanted a better quality…i was able to use my fogs on that with no problem..
Engine: standard
Thanks bro…I do have to order some of those pieces as well(grill, and side pieces)..there are 2 plastic pieces/covers where the fogs sit that i have to order too.. will my 04 fogs fit in these covers?..Also do i really need to have the brake vents changed?
My bumper is a BMW OEM Mtec bumper and the fog light assembly is a all in unit. Free form fog light, bulb assy including all hardware from BMW, same with grill, 2 cover plates and vent duck assys. All OEM BMW parts. Look at REALOEM.com for the parts you need....
You will be happier with the real deal and quality, that and the price difference via the net isn't that bad...
Engine: standard
tjackson9810
04-21-2015 07:42 PM
umnitza
04-16-2015 04:39 PM
blackstarr
03-05-2015 04:54 PM
