OBD Error code p1434???
My Ride: AW E46 M3 Vert
i got a service engine soon light today and i-drive said increased emissions, i went to autozone to have the obd read. guy told me the code is p1434 and looked it up on his computer and the code came up for a Volkswagen on his computer which was weird but the definition it gave was secondary air injection pump realy circuit short to positive anyone know what i need to replace to fix this? the car is out of warranty.
thanks
thanks
Weird... Use the search for different things related to "increased emissions" warnings... Heres a few things that can trigger it...
1. faulty or loose gas cap, or over flowing of gas.
2. faulty o2 sensors
3. faulty dmtl pump
4. faulty fuel pump
5. faulty/dirty mass air flow sensor
6. use of low octane gas
3. faulty dmtl pump
4. faulty fuel pump
3. faulty dmtl pump
4. faulty fuel pump
3. faulty dmtl pump
4. faulty fuel pump
I just noticed you have a KN filter and Charcol removed... that could be part of your problem right there. Not so much the charcol, but those KN filters are SMUTHERED with OIL, Its usually good idea to lightly rinse and dry them.. From what I think, the OIL has gotten onto the MAF which is causing the message.
Do you have poor gas mileage? Rough idle? Poor acceleration? If any of those, my bets are on the MAF sensor.
so where is this MAF sensor located and do i need to replace it or just rinse the filter?
thanks for all your help
Usually the problem starts to occur sometime after the install of these over oiled filters... The MAF, mass air flow sensor, is in the tube, that goes from the intake box, to the engine, you can see a plug going into the sensor. Im not 100% Sure if this is the problem, but sure does sound like it... Those sensors are fairly expensive, perhaps got the code read from bmw just to make sure its the issue.
thanks
thanks
so basically the MAF sensor i have now is messed up since the oil got into it, it cannot be fixed right? if i do replace the sensor will the k&n mess it up again? what can i do to prevent this from happening again? i though lots of people on here had the k&n, strange that only a few people are experiencing this.
Originally Posted by MacoBMW4life' post='773951' date='Jan 21 2009, 07:06 PM
i just got that msg in my i-drive today too....and enging pic in the display dash. I will take it in tomorrow or Monday to get it fixed. I'm really hoping it's just a simple sensor since i'm out of warranty too. 87k miles on my car.
