Noise when going over bump's
Old 10-20-2011, 10:24 PM
bmwbimmer's Avatar
My Ride: Bmw e60 530i _-_ professional navigation- mystic blue exterior- beige interior-logic7-18 inch rims-active steering-bluetooth-adaptive xenon lights-sunroof-sport steering wheel-comfort seats-tv-pdc
But I don't think I will need that because I have stock 18 rims
Old 10-21-2011, 05:40 AM
jgt
jgt's Avatar
My Ride: E60
Engine: N52
Did you put the car on a lift and check out all the suspension and steering components?
Old 10-21-2011, 06:40 AM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
You have to see if its actually the fender/tire contact making the noise. If it is, and if you have stock 18's and stock suspension, I would say you are probably running on a bad component of that suspension somewhere... Gotta do a bit of work here to help us help you. Pics, video, a good description of what you found underneath or with the wheel turned... something.
Old 10-21-2011, 09:58 AM
mels545's Avatar
My Ride: 95 M3 CAI, chipped, pulleys, Xbrace, doesn't give headaches every time I start up! 04 545i all the goodies INCLUDING HEADACHES!
check your front strut support for tightness. It's the bar that runs across the engine compartment from the tops of the struts.
Old 10-21-2011, 01:17 PM
bmwbimmer's Avatar
Yes I did all is ok ...
Old 10-21-2011, 01:20 PM
bmwbimmer's Avatar
I
Old 10-21-2011, 01:21 PM
bmwbimmer's Avatar
I will post some pics later for the tire in contact with the fender, I saw the fender on the right it seems like bend into the inside, and when I saw the left fender it was straight, its only the right tire that makes contact with the fender.,
Old 10-21-2011, 01:26 PM
bmwbimmer's Avatar
Ok will do
Old 10-21-2011, 03:17 PM
jaycal3's Avatar
Originally Posted by bmwbimmer
So what's the solution for this ?
So how did you solve the problem
Did anyone had this noise ?
Hey bmwbimmer, just a friendly suggestion... use the MultiQuote function so you can reply to numerous posts all in one...
Old 10-22-2011, 05:11 AM
bmwbimmer's Avatar
Thanks for makin it obvious
Quick Reply: Noise when going over bump's
