noise coming from rear / rear doors
There is a sqeaking / creaking noise coming from the rear of my 530. <_< It sounds like rubber rubbing together and I'm assuming it's the door seals. Anyone else have this problem? Is there a service bulletin for this?
Door and window seals creaking/squeaking has been an issue for some. There were several postings a few months ago on this - try the search function. There is a cure for window seals.
Yesterday mine developed a rattle in the driver door panel. Probably a loose clip. I opened the door, dropped the window completely, closed the window and closed the door with a hard slam. Problem sorted. Try it on both rear doors ! Also check the seal fittings under the door - I had a loosed one on my old 3 series which squeaked (was actually replaced by the dealer to fix it).
Regards
DrT
Regards
DrT
