No side lights
Old May 11, 2013 | 07:45 AM
nutta_e60's Avatar
My Ride: F10 M sport
Model Year: 2013
Engine: 520d
Default No side lights
Hi i wonder if anyone on here can help me out. I did a retrofit from pre lci adaptive headlights to lci adaptive headlights. I followed the bmw instruction& used the retrofit kit added +mueb& now i have a side light fault. Both sides do not work everything else is working fine. Any info would be great.
Thanks
Old May 11, 2013 | 02:03 PM
BlaSTiWi's Avatar
Just to make sure the term is the same ... side light = the round AE (parking light)?
Old May 11, 2013 | 02:49 PM
nutta_e60's Avatar
Model Year: 2013
Engine: 520d
Yes that is correct. What i don't understand is my welcome lights work fine which is of the same light.
Old May 11, 2013 | 03:27 PM
BlaSTiWi's Avatar
Ahhh OK ... so did you do the LCI tail lights too? Do you re-call moving AE pins on the LCM?
If I remember correctly when I did my conversion I moved the pins on the LCM for the AE 'cuz the new AE require 35w as oppose to 10w on the pre-LCI.
Old May 11, 2013 | 07:23 PM
nutta_e60's Avatar
Model Year: 2013
Engine: 520d
Yes i did the tail lights aswel. There was no mentioning of moving AE pins in the bmw retrofit instructions. Do you by any chance still remember which pin it was exactly?
Old May 12, 2013 | 05:26 AM
BlaSTiWi's Avatar
Ahhh that's probably why ... try & chk then move pin #25 -> pin #63 (GR/GN) and also pin #40 -> to pin #11 (GR/BL) on the LCM (X12) plug, this step is at the end of page #14 of the LCI conversion instruction doc from BMW.
GL!
Old May 12, 2013 | 11:31 AM
nutta_e60's Avatar
Model Year: 2013
Engine: 520d
How can i thank you i dont understand how i missed that bit.
Thanks again
Old May 12, 2013 | 02:57 PM
BlaSTiWi's Avatar
Hey NP ... glad I can help.
Kasmo
May 7, 2019 03:30 AM
justalilbit
Apr 28, 2015 05:36 PM
thesalboy
Apr 8, 2015 09:13 AM
rizwan1377
Apr 5, 2015 05:22 PM
