No oil leaks but huge oil loss or consumption.
Old 06-18-2020, 08:13 AM
  #21
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
You love your car.
Post a picture.
Old 06-18-2020, 10:34 AM
  #22
Tejas's Avatar
My Ride: 2008 BMW 528i
Engine: N52K
Razzy530 (03-05-2024)
Old 06-18-2020, 11:01 AM
  #23
My Ride: 528i
Engine: N52k
It looks nice and clean.
Have you clay barred it?
Old 06-18-2020, 12:18 PM
  #24
Tejas's Avatar
Engine: N52K
not yet. thats on my to do list. this is just hand wash and wax. the car was surprisingly clean even after 4 weeks. I also have headlight lens cleaning and engine bay cleaning to do as well.. i hate all the oil leak residue...
Old 06-18-2020, 09:03 PM
  #25
donpb's Avatar
My Ride: '06 530i N52
Originally Posted by Tejas
i bought the car 5 months ago. just ticked to 120k miles. bought it at 100k miles. all of the 20k miles is pure highway. most of it bw TX and NJ. no way in hell i am selling this car. i agree the problems are not something i can ignore. but its not something that will make the car run less efficiently. its just standard fixes you have to do at this milage. My e46 needed 2 headgasket replacements and an engine rebuild. after doing all that this is a piece of cake for me. time consuming, definitely.worth the effort. YESSS.. I love my bimmer and will do everything to make it right. this car takes me 1000s of miles without ever dropping below 500 miles to the tank. thats an indicator the engine is good. but needs a bit of maintenance but i love her..!!
If its a piece of cake then by all means DO it. I used to have an e46 also but I sold it to get my e60. I had both of them for awhile because it took a long time to sell the e46. I also had an e36 at the same time. Three bimmers. Yep I was crazy back then. Right now I just have the e60 and recently got an f30.
Something tells me your CCV and associated hoses could be the culprits. They get brittle over time and break easily. Maybe something broke when the dealer worked on it. I broke my CCV hose while replacing my starter and didn't even know I did. I just replaced that one hose but I also saw a kit that has the CCV and all hoses.
Old 06-19-2020, 05:11 PM
  #26
Tejas's Avatar
Engine: N52K
i think you are right. it could be the hoses. the dealer had done a pcv valve replacement for free maybe he damaged something there. i am removing the intake and the valve cover. i saw some leaks behind the valve cover. could be the ccv hose.
il keep you guys updated
Old 06-19-2020, 05:28 PM
  #27
donpb's Avatar
Yeah I recently got that PCV heater recall work done too. And its right in the area where the hose was broken actually that's the hose that comes from the crankcase to the CCV. I think I broke it or maybe they did. Who knows? My car also loses oil but my indy mechanic says its my oil pan gasket leaking. Its not that bad, I only lose like a quart of oil every 8-9 months.
Old 06-22-2020, 08:09 PM
  #28
Tejas's Avatar
Engine: N52K
So I finally got around to degreasing the CCV pathways in the valve cover. I used a gunk cleaner and sprayed almost half a can before it started to spill out the other end. ( i sprayed from the outside of the valve cover where the pcv hose is attached). I then pressure washed it with water and engine cleaner at a self service car wash. I washed the Intake manifold as well. there was some oil in the intake manifold. Now to the thing thats confusing me --> no leaks under the intake manifold or behind the valve cover. I have cleaned the remaining oil leak deposit i had from the OFHG. the only leak i have is the oil pan gasket and i do not think its leaking that bad. Anyways i hope this will solve some of my problems. I am going to install a catch can in the next week or so. I could not find a hose that goes back to the oil pan. i do not understand how this ccv works but its a BS system. I will do the changes and report back.
In the photos you can see the new membrane i have installed. its not as complicated as it feels. next thing on the list is oil pan gasket. need to see how much of an improvement that makes.
Any other oil leaks in this engine ? i can check those too and make sure its good.
Old 06-22-2020, 08:51 PM
  #29
donpb's Avatar
Wow looks pretty.
Are you going to replace the intake gaskets?
Old 06-22-2020, 09:31 PM
  #30
Tejas's Avatar
Engine: N52K
yes but not now. they are in the mail and il replace them later along with throttle body gasket.
Quick Reply: No oil leaks but huge oil loss or consumption.
