No heating in the car
I struggling to find the fault with this, i have a e60 545i 2004 with 144k miles, I have changed the water pump, changed the thermostat, checked the idrive settings, have always got the climate on hot and auto but constantly blowing cold no matter how warm the engine gets, water level is a steady constant, fan kicks in as it should. Done the 12 minute bleed, but still no different, even checked the alternator voltage, 13.9-14.1 volts, any ideas guys.
Funny you mention it. I have a 2006 550i, the air temp eventually warms on cold days however it seems to take forever. Changed out the radiator, water pump and thermostat in the past year. Coolant is at appropriate level. Would also be interested in any potential explanations/remedies. Not familiar with "the 12 minute bleed" however.
Thanks! Ed |
I would check the heater core valve and the heat blend door actuator.
(Post 1577837)
Originally Posted by EddieboyS
(Post 1577833)
Thanks! Ed |
Thanks! That's 10 seconds, how/where do the other 11 minutes 50 seconds apply?
(Post 1577861)
Just checked other postings on the 12 minute bleed process. Apparently it only works with electric water pumps. The 550i has a mechanical water pump.
(Post 1577866)
Thanks, tried it this past weekend and received a low coolant message afterward which indicates that the heater core was not completely filled prior to the bleed.
