NO HEAT ! and its fall !
Hey guys i have a 2006 525xi and i cant get heat noooooooo where in the car, and its almost winter in Canada. If i turn the idrive to hot then turn the temperature dials to the max and fan to the max all i get is air blowing out the top of the dash(defroster vents). Air condition works perfect and is freezing cold. The air ambient temperature sensor is broken giving a really high reading, dont know if that could be the cause. Please any help is very appreciated.
Thanks
Randy Rashid.
Thanks
Randy Rashid.
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Thanks
Randy Rashid.
Thanks
Randy Rashid.
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Thanks
Randy Rashid.
Thanks
Randy Rashid.
Because your car's heating system works off of the cooling system, sometimes, heating system malfunctions are caused by problems in the cooling system. One of the first things to check when your car heater is not working is your engine coolant level. If your car has a coolant leak in the cooling system, the heater will not be able to produce adequate heat. In any event, to keep your car running optimally, you should regularly check the coolant level. For safety reasons, this absolutely must be done only when the engine is completely cooled down. This safety point cannot be over-emphasized.
Opening the cooling system of a hot engine presents a terrible burn hazard, as the fluid in your car's cooling system is dangerously hot and pressurized when the car has been in operation. It is best to
If there is too little coolant in the reservoir, you should be alert to the possibility that there could be a leak somewhere in your car's cooling system, but you may nonetheless remove the reservoir cap and add coolant to the Full-Cold line. Obviously, if a very short time after you refill the coolant reservoir, the coolant level is low, there is a leak in your car's cooling system. Many points in your car's cooling system are liable to develop leaks through which coolant can escape. Too little coolant in the cooling system will result in a malfunctioning heater. To inspect for a leak in your car's cooling system, you should understand that the main physical components involved in the cooling system:
Engine block
Thermostat
Upper and Lower Hoses
Radiator
Radiator Cap
Radiator Fan
Water Pump
Heater Core
Heater Hoses
Heater Blower Fan Motor
A leak in the heater core occurs most often in escaped coolant on the heather core area!
No i fully understand the coolant system on regular cars, but isnt this a little different? my 240sx with sr20det has everything but doesnt have electronic heater valve ect. I just ordered the ambient temp sensor.
My Ride: 05 BMW 530I
Thanks
Randy Rashid.
Thanks
Randy Rashid.
Well like I said you go step by step first the basics then the electronics such as switches,sensors,thermo couplers,etc.
eh, so what was the verdict on this one? did you replace the sensor and did it work?
My heat wasn't working at all and I replaced the Thermostat (and waterpump because it had the plastic impellars... don't have to replace though) and heat works great...
My Ride: 07' BMW 550i
you stated, air temp sensor is broken, showed a high temp, it might not broken, it can be just disconnected. Check your temp sesor, all system works from temp sensor, your temp regualtor is working from temp sensor reading.
