No car lock "beep" with upgrade
Old 01-22-2007, 09:01 PM
Rob
Rob's Avatar
I recently had my car upgraded to CIP 24.01 to fix a host of issues. When I noticed the "eyebrows" no longer worked, they changed the car to CIP 24. That fixed the eyebrow issue, but left me with this one:
When I lock the car, I no longer get a "beep." I still have the beep when I unlock, just not when I lock. (this issue was also present in 24.01)
The dealer has no idea about this one and told me to call them in a month or so to see if there is a fix.
Has anyone else seen this issue? Any idea if this is fixed in a later rev of the software?
I have left my car unlocked a couple times because occassionally the lock button doesn't actually work. Without the beep I'm never sure if I've really locked the car or not.
Thanks
Old 01-22-2007, 10:07 PM
EBMCS03's Avatar
I assume you checked the iDrive already to make sure the acoustic tone is checked... for when you lock the car... even if it is checked now... try unchecking go for a drive... lock and unlock your car a few times then re-checking the box... see if that fixes your problem.
Old 01-23-2007, 01:46 AM
the-oneil's Avatar
Oh, I never got a beep from either locking or unlocking <_<
I do get light confirmation, but no beeps. Could it be because it is a UK car
Any UK members could please confirm if you get a acoustic confirmation after locking your car?
Thanks
Old 01-23-2007, 02:12 AM
MAK
MAK's Avatar
As above ...go into i-Drive menu select... "Vehicle settings"... then "Door locks"... then "Confirmation" and tick the boxes you want. See what happens!
My UK manual shows the acoustic settings and visual settings as options.
I have selected the visual but will try tonight and see if i can opt for the "beep" as I can't remember ever trying this setting.
Old 01-23-2007, 02:24 AM
papereyes's Avatar
No Beep from my car either.
only have an option for visual confirmation
Old 01-23-2007, 03:03 AM
the-oneil's Avatar
Ditto
I don't have any options for acoustic confirmation
Old 01-23-2007, 06:32 AM
Rob
Rob's Avatar
Good suggestion, but I already tried it. I even turned the beep off in IDrive, waited over night so the car went to sleep, reset it in the morning, and still no beep.
If no one else is seeing this after CIP24, then perhaps something else is messed up with my car...
Old 01-23-2007, 08:29 AM
ivan545's Avatar
Hi, Rob
I just dropped off my car for the eye brow issue to be fixed today, and other services, so i'll check on that when i pick up the car and keep you posted.
Old 01-23-2007, 08:33 AM
Ricracing's Avatar
No beeps here either, lucklily
Just blinks from the turn signal lights.
Old 01-23-2007, 09:26 AM
VTbound's Avatar
My Ride: 2005 e60 Titanium grey Auburn premium Sport 6-speed Logic-7 folding rear seats with ski bag Bi-xenon Cold weather package
Do you guys with no beeps have alarms? I don't know if this matters or not, but it might.
Quick Reply: No car lock "beep" with upgrade
