Sponsored by:
Sponsored by:
LCI E60 headlight vertical aim adjuster broken
Old 11-12-2010, 12:31 PM
325/528's Avatar
I tried searching but did not come up with anything.
I broke the vertical headlight adjuster on my 08 528xi and it needs to be replaced. Is this a DIY project or does there need to be any coding done? Anyone have any clue?
Thanks in advance.
Old 11-12-2010, 02:56 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
Thanks in advance.
check out www.realoem.com for diagram and part numbers. not sure about coding.
Old 11-16-2010, 05:33 AM
325/528's Avatar
Ended up getting it at local dealership. Part and install for about the MSRP of the part.
Old 11-16-2010, 07:38 AM
tsaros's Avatar
My Ride: 535d -08 lots of goodies 120dA -06
How did you break them?
This was a very common problem on the e39´s where the plastic got so fragile that they broke by them self.
I am kind of hoping that the e60 is less prone to breaking in the same manner.
Old 11-18-2010, 07:02 PM
325/528's Avatar
I broke it changing the struts. I forgot to disconnect it. My bad!
Kasmo
05-07-2019 03:30 AM
milhouse4u
04-22-2015 04:43 PM
rizwan1377
04-05-2015 05:22 PM
ZeZe
10-15-2003 12:58 PM
08-12-2003 11:41 AM
Quick Reply: LCI E60 headlight vertical aim adjuster broken
