New Transmission coding?? Reading old,coding to new!!
Old Sep 23, 2013 | 11:07 PM
yellowbrick2000's Avatar
My Ride: 2004 e60 530i
Default New Transmission coding?? Reading old,coding to new!!
Replacing my tranny and need some info on coding the new one to the old specks.
Any input on software and etc.
Thanks
Old Sep 23, 2013 | 11:12 PM
west's Avatar
Are you converting from a manual to auto or auto to manual?
Old Sep 24, 2013 | 01:54 AM
Only Bimmers's Avatar
My Ride: 98' 528i Manual07' 550i Sport
IF this is actually a new or re-manufactured transmission it will need to be programmed and coded. They come blank from the factory and aftermarket suppliers. Did you read the config before you removed the transmission to know what you had?
If you are installing a used transmission you are going to have to do some poking around the forums to see what if anything can be done to change the vin, etc and program it. Some transmissions cannot have the program downgraded without causing damage or malfunction.
Old Sep 30, 2013 | 09:48 PM
No it's still in the transmission!!
So, I want to read it then write it to the new/used transmission.
Hopefully I can get it fixed... It needs transmission replacement, have had issues and its recommended that I replace it.
I guess it time to learn inpa and etc....
Stranger12
Apr 5, 2015 10:42 AM
BLACK_PRINCE54915
Apr 2, 2015 08:11 PM
silver4evr
Lounge
Mar 21, 2004 06:38 AM
jonboy
Mar 20, 2004 07:38 AM
