I got my E61 updated to v18 and now I got a new option in the ligth setting menu. In Car settings- Lights I now have an option of "Running daylight". The only problem is that I have no idea of Running daylight might be and becouse it's a new option in the iDrive it's not mentioned in the manual. I have tested to switch it on and off but I cant see any difference anywhere.
Any one got an idea? |
When you select the running daylight option your lights will remain continously on (at a lower setting) if you have the Lights switch on Auto mode. If not the light sensor will turn them on or off according to the light conditions.
Hope this helps |
It's for putting on your highbeams on a low wattage when you drive during the day to give extra visability. It's very comon in the USA and I have seen some audi A6's drive around over here with the DRL's on too..
