New owner, iDrive+MP3 questions
My 530xi was built in 09/2009 with no nav, but it doesn't play MP3's. I haven't taken it to a dealer yet because I want to make sure that I've got everything straight. From everything I've read, 06 models with no nav built after 09/2005 should be able to play mp3's from the factory. It's only the nav equipped models that need a software update to enable the mp3 functionality. Is this correct?
Secondly, (possibly related) I've read that the idrive screen background changed from brown to silver at version 24. My idrive background is still brown, indicating that I have an old version correct? Could this be the reason that I'm unable to play mp3's? Everything that I've read says that I should have the capability from the factory, but is it possible that I got one of the first September builds with older, non MP3 capable software?
I understand that the dealer's won't update the idrive software unless there's a problem with it, would this (not being able to play mp3's) qualify as a problem, forcing them to update the software under warranty?
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather.
Mods:
Carbon filter removed.
M5 iDrive knob.
Umnitza license plate LEDs.
MP3
40% 3M tint
ACS Anti-Roll(sway) bars
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
It really should be able to play MP3s from the factory but not MP3s in the CD changer. MP3 functionality is available here (US) for cars that didn't originally come with it and is covered under the warranty. There is an SIB in a thread here somewhere but it has copyright BMWNA so would probably cause your UK dealer to disregard it, there was some technical info in there as to what kind of system the update worked on.
EDIT:
SIB for US http://forums.e60.net/index.php?act=attach...st&id=92282
Other MP3 thread http://forums.e60.net/index.php?showtopic=24018
EDIT:
Mods:
M5 iDrive knob.
MP3
40% 3M tint
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
Actually I might be wrong about non nav (MASK) units and MP3...I'll shut up now and let someone else take over!
EDIT:
EDIT:
I've burned mp3 CD's with three types of media, using itunes, windows media player and Vista's cd data burning function. None work, they all spit out a "cannot read media" error. Using the same types of discs, I burned standard audio cd's and those play fine, so I know it's not the media that's the problem, the car simply can't read the mp3 cd's.
This is just strange, does anyone have any ideas what the issue could be? I just want to have more info before going to the dealer. I'm just worried htat they'll claim that I'm not covered under warranty, since the SIB only covers cars with navigation.
![Welcome](https://5series.net/forums/images/smilies/imported/welcome.gif)
Mods:
M5 iDrive knob.
MP3
40% 3M tint
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
Update your location that might help, there are some Canadian members that could give some input if there are issues with Canadian BMW dealers. You have all the info to go to the dealer, only thing I might try before the dealer is burning from another PC or getting an MP3 CD you know works in another vehicle.
I doubt that it's my PC, as the car did read standard audio discs burnt on 3 different types of media with the same PC. I tried 3 different programs with 3 different types of media for mp3's, none work.
Model Year: 2010
Earlier CCC software was unstable, so MP3 playback was programatically disabled. It can be re-enabled for free during the warranty period:
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B651805g.htm
MP3 CD-R should be burned no faster than 8x, using the file system format of ISO 9660 1999
With SIB and newer PROGMAN/CIPS software, even a 2004 E60 with CCC plays MP3 CD in-dash.
I guess that answers that for mp3's.
My other question was about iDrive. Am I right in saying that I have a pretty old software version? I believe it was version 24 that went to a silver background, and it's on version 34(?) right now?
