New N54 install issues.
Rebuilt N54 finally in place.
The motor starts right up, idles rough and dies. I cleared all faults before starting. The injectors have been programmed. I am getting intake and exhaust VANOS errors, misfire errors on a couple of cylinders and a vacuum error on one turbo. 1. The VANOS are new. I did pull and bench check them on the bench and they check out fine. 2. Plugs are new, I don't know enough to be sure the misfires aren't related to the VANOS error. 3. I traced the vacuum lines all the way back to the vacuum pump and everything looks good. I have looked for a wiring diagram for the VANOS and cannot find one. Anyone with any ideas? This newby thanks you in advance. |
With that behavior, I'd monitor the fuel pressure and see if it's trailing off as you start the car...
| All times are GMT -8. The time now is 06:31 AM. |
