New N54 install issues.
Rebuilt N54 finally in place.
The motor starts right up, idles rough and dies.
I cleared all faults before starting. The injectors have been programmed.
I am getting intake and exhaust VANOS errors, misfire errors on a couple of cylinders and a vacuum error on one turbo.
1. The VANOS are new. I did pull and bench check them on the bench and they check out fine.
2. Plugs are new, I don't know enough to be sure the misfires aren't related to the VANOS error.
3. I traced the vacuum lines all the way back to the vacuum pump and everything looks good.
I have looked for a wiring diagram for the VANOS and cannot find one.
Anyone with any ideas? This newby thanks you in advance.
