New gasket for trans oil pan?
Old Jan 23, 2017 | 04:33 PM
Justcosmo's Avatar
My Ride: 530i
Default New gasket for trans oil pan?
hello everyone, looking for advice on whether I need to replace the gasket for the oil pan that was replaced 10 months ago. I had the trans fluid changed then and replaced the new oil pan and gasket, unfortunately I need to replace the mechatronic sleeve due to bad leak and wonder if I can keep the gasket after 10 months of use. Any help is greatly appreciated. Thanks!
Old Jan 23, 2017 | 04:41 PM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
The existing rubber gasket that fits in the channel of the pan is probably ok, but for piece of mind, I would change it out and have the job complete when you finish, rather than be concerned of a pan leek. Also get a new o ring for the plastic drain plug.
Good luck.
Old Jan 23, 2017 | 06:58 PM
Justcosmo's Avatar
My Ride: 530i
Good luck.
thanks for the advice. I am also looking for tips on replacing the mechatronic sleeve, specifically how to access it with limited space to work with. I have the instructions on how to change it out but heard from many members who have done it had a hard time accessing it.
Old Jan 25, 2017 | 04:33 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Yes it can be a little hard to reach it but it is doable. I had mine out in less 5 mins and it took me another 5 mins to put back it. Just make sure when you put it back in it is seated all the way. You should feel a click.
Old Jan 25, 2017 | 04:40 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
That's amazing.
I had mine out in 30 seconds but probably 20 minutes to get back in. I haven't worked on old Minis for a few years now so my telescopic fingers have fallen off and my elbows no longer bend backwards.
Old Jan 25, 2017 | 07:55 PM
Originally Posted by ripley
That's amazing.
Using curved needle pliers makes it easier to get in
