I am now the proud owner of a 2008 535i sedan with 6MT (I would never drive AT), Premium, Sport and iDrive. I also own a 2009 335i sedan 6MT (not for long) and used to own another 2007 335i sedan 6MT.
In comparison with E90's, I have a some positive things to say about my 5, some negative and a bunch of questions. Here they are: Positive:
Negative:
Questions:
http://www.postimg.com/65000/photo-64297.jpg |
Originally Posted by Razor1973
(Post 1432329)
Negative:
Questions:
http://www.postimg.com/65000/photo-64297.jpg For ECU tuning, I would go with a COBB loader since it's a simple plug and play type software without having to actually pull any of the wires for the ecu. Search COBB tuning. I take it your does not have the active steering option then, it really makes the steering responsive and stiff. I'm not sure there is a way to retrofit it or make your steering any more stiff or response. The weather sealing can be found here: http://www.ecstuning.com/BMW-E60-550...indow/ES92982/. Not sure about the DVD squeaking, mine makes a few seeking noises as well but I've just learned to ignore them. The CCC to CIC upgrade is very costly, $3k sounds about right. Not worth it in my opinion. Plenty of other mods, especially for a 535, that could be done for that kind of money. Welcome to the forum! |
I have the Burger JB4. LOVE IT!!!! You can quickly turn it off by using your controls on the steering wheel. Not detectable if turned off and you have to go to the dealer for something. It's a plug and play but does require you to pull a few things out of your box to plug in (splice. Connection). Several different MAPP programs to select from on the fly. And the best thing is that Terry Berger is the best and stands behind his product.
As for your vent, remove the wood trim. The vent has probably become unsnapped. |
Welcome to the forum.
JB4 + 535i = :hyper: :twoup: :dance: :clap:
Unlike an ECU flash, you can simply remove the harness/CPU when you don't want to keep it anymore. You may find someone trying to sell a used one here or on Ebay, etc. |
the steering feels light because you do have active steering. i didnt like it at first but now when i drive my girlfriend's 3 series, i appreciate the active steering that i have in the 5. you will get used to it.
Originally Posted by karman
(Post 1432494)
Originally Posted by tonyb635
(Post 1432383)
As for your vent, remove the wood trim. The vent has probably become unsnapped. It isn't the actual vents that became unsnapped. I will take photos and post later.
Originally Posted by dploy
(Post 1432471)
If your windshiels were to 'accidentally' crack your ins comp will replace the glass & gasket free...
Originally Posted by pukka
(Post 1432481)
Originally Posted by dantheman1
(Post 1432496)
My brothers 328 with regular steering feels very light at low speeds and needs many turns of the wheel to achieve a sharp turn.
Thank you all for your warm welcome! |
active steering came with sports package. either you have it or you dont have active steering
(Post 1432499)
| All times are GMT -8. The time now is 12:15 AM. |
