New battery :(
Old Jun 16, 2009 | 11:50 AM
paul1994's Avatar
Well after searching the forums and doing a little research I just replaced my battery with this one
http://www.batteriesplus.com/products/61-S...CCA/545I/1.aspx
Also After looking at autozone the battery they recommended was not the same specs. They gave me a battery with a 650cc when the OEM was 850cc
I installed the battery and had the Active steering error. I turned the steering wheel both ways and the error was cleared when I restarted the car.
Overall the process was easy and I personally could not pay someone to $400 to change the battery.
Old Jun 16, 2009 | 12:10 PM
luigi524td's Avatar
Thumbs down
Good choice - never install a replacement battery with a lower CCA than original equipment; BMWs are very hungry for volts even when parked!
Old Jun 16, 2009 | 12:21 PM
Ricracing's Avatar
Hope it will hold.
Old Jun 16, 2009 | 12:22 PM
CWS530's Avatar
Good work. Looks like solid equipt.
Old Jun 16, 2009 | 05:09 PM
thedreamshop's Avatar
My Ride: 2004 545i titanium grey 6 speed manual with light grey interior. Nav, L7, cold weather, sport, sat. Modifications: suede headliner, pianno black interior trim, Ipod dock, Mtech front bumper, Angel Eyes, and flat black kidney grills.
The car needs to be programmed to know that your battery was replaced otherwise you could get battery warnings even when the new one is still good. BMW efficient dynamics has some algorithms or something that keep tabs on your battery life and need to be reset after battery change.
Old Jun 16, 2009 | 09:08 PM
gwf545's Avatar
My Ride: 2015 535D M Sport
Not so. The only time you need reprogramming is if you change the battery type to another type that requires a different charging rate. Search the site to get details.
Vman33
Mar 14, 2022 04:43 AM
derooster
Sep 22, 2016 07:30 AM
fabolous531
Oct 18, 2015 12:22 PM
LandRange
Oct 5, 2015 08:47 AM
LandRange
Sep 6, 2015 10:39 AM
