New 545i Review
My Ride: '04 545i/6sp SilverGray/Beige
Originally Posted by drinkh20' date='Jun 1 2004, 11:03 AM
Rudy-
Thanks for the reply. If the engine was running hot or close to overheating what would the lines show and where? Is this an actual temp gauge or does it serve another purpose? I assume that if the engine was running hot you'd receive a message in the message center or the I drive.
thanks
thanks
During the time that I drove my ED 545 in Germany, I never saw more (or less than) four bars of "variable redline" once the car got up to temp. But in a brand new car, one would hope that the motor would not overheat. It was also not so cold in the mornings that it took the engine very long to heat up.
Most modern temp gauges are not indicative of the actual enging temp, just indicators that the temp is either OK, or trending up or down.
I would love it if the iDrive system were to be extened to allow us to have a "virtual gauge set" displayed on the monitor that included charging system voltage, water and oil temp, and oil pressure. Surely the car's ECU is monitoring all that stuff already; it wouldn't be a huge deal to build a view of it in iDrive.
-MrB
Originally Posted by mrbelk' date='Jun 1 2004, 11:37 AM
(snip)
-MrB
-MrB
I think I understand now. The white lines aren't an engine temp gauge at all, rather, it's a variable redline that is telling you not to exceed a certain rpm due to the engine not being warm yet. As the engine warms the lines decrease and fall towards the actual redline.
Originally Posted by JDN' date='Jun 1 2004, 11:42 AM
[quote name='mrbelk' date='Jun 1 2004, 11:37 AM'] (snip)
I would love it if the iDrive system were to be extened to allow us to have a "virtual gauge set" displayed on the monitor that included charging system voltage, water and oil temp, and oil pressure.? Surely the car's ECU is monitoring all that stuff already; it wouldn't be a huge deal to build a view of it in iDrive.
-MrB
-MrB
Certainly doable (I assume). I wonder what the proper channels would be to suggest something like that? For us US BMW owners, we could all send a "priority email" from the Owner's Circle website. If enough people offered that suggestion, it might stir some interest. It wouldn't require any new main menus, just a different view in the "Car Data" section.
I would also like to see the system "remember" where you were when you shut the car off and go back there when you get back in (after "accepting" the disclaimer).
-MrB
Hey drinkh20 I'm a Gallery guy also, about 45 miles so. of Boston, Kingston. There are a few guys at Gallery that are good customers of mine. I've posted on THE OTHER BOARD about their knowledgeable service guy's and I've found they are good people to deal with. I havn't seen another 545 yet but I'll keep an eye out for you, should be easy to spot since NOBODY has the reflectors, or even a clue what they are. 30 miles south, on the ocean huh.........I'm thinking Hingham?
In this case, abnormally low or high engine temps should alert you to not rev the engine past a particular value. In the "old" way, the driver would have to "guess" what is a safe max RPM value, but in this "new" way, the system saves us from having to make that determination ourselves, and just "tells" us what is a safe RPM given the engine conditions.
-MrB
