Need your help on offset for 18" on my 530XI
My Ride: 2007 Silver Grey Metallic 530 Xi E60
Black leather, Nav, Adaptive Xenons, AWD, Comfort access, NightVision, Cold Weather Package, adaptive xenon headlights with headlight washers, PDC, glass sunroof, Ipod, park distance control, retrofited auto dimming power folding mirrors, Window Tint Front 35% / Rear 20%
I'm interested in getting a set of 18" Wheels 189 style but I am confused on the offset, will this offset fit on my 07 E60 530xi.
- Front: 225/40/18 offset 34
- Rear: 255/40/18 offset 37
The offsets should work OK ... as I'm sure you know the optimal offset is 43 ... that said, the front tire size is (I assume this set-up is from a 3 series) is too small for your e60. You might want to consider fitting the proper size 18's all the way around (245/40x18). Also confirm the wheel center bore is correct as well (72.56mm).
Hey Luigi, thanks for the reply, yes they are from the 3 series, I like the look of this wheels but I'm a little concern about the offset,
Offsets are good, tires are not. Do some research - the overall rolling diameters of front and rear wheels must match closely (within a few mm's). Plus, the front should be 245/40/18. That would put your rears somewhere in the 275/35/18 territory. But I'm just guessing here, search for a wheel diameter calculator to get the exact sizes.
