Need the type of screw
Can anyone tell me where to find the sepcific screw needed for this part. It is a semi-moveable piece of hard plastic that is beside the brake ducts on both left and right sides. It is on the interior of the car, near the inside of the wheel/suspension part, not on the exterior of the car. There is one single screw on each side holding this piece in-it is on the upper portion of the vertical area where it is held by one screw to a more solid piece that is between the brake duct and this piece. I believe it shields dirt from getting up into the suspension from the ground while driving. Problem I am missing the screw on one of them and it is making a loud sound when accelerating.
The headlight reservoirs have the same screw in them--to keep the fluid from leaking out at a high rate of pressure.
umichchris
12-10-2015 01:00 PM
AirlinePilot
12
09-12-2015 09:39 AM
