Need Some Urgent Help
Old 04-30-2013, 11:24 AM
///M-Power's Avatar
Default Need Some Urgent Help
Whats up brothers my car recently started having the rpm jumping problems and reving the engine every time it jumps up. The car threw an service engine light so i went and took it for diagnostic mechanic told me its the oil separator and charged me $400 to replace it after that car still does the same thing only happens on cold starts doesn't happen when the car is warm told the mechanic car does the same thing he told me when he drives it it doesn't and he cant go off my videos he needs to see it happen when his driving the car so he basically fucked me over he guaranteed that thats the problem the car doesnt throw any codes or anything need some help.
The Shops Name Is Hamlet's BMW In Glendale CA Very Dishonest Person
Old 05-01-2013, 12:51 AM
turboawd's Avatar
My Ride: 2006 BMW 550i
are you in motion in the video? it could be your trans torque convertor locking and unlocking repeatedly. it used to happen in an old 3 series i had. they told me the trans needed to be resealed.
Old 05-01-2013, 12:09 PM
Ducmaniak's Avatar
My Ride: 2005 545 6MT
look in the hidden menu for the voltage, if it drops when the rpm increase, have your alternator checked. I just replaced my alternator for the same reason. I did a lot of other cheap stuff before that, but alternator was the only thing that fixed it for me. What happens is the computer sees a drop in voltage (in my case as low as 10V) and it will run up the revs trying to get the voltage to an acceptable level.
Old 05-01-2013, 02:37 PM
Texas_Vol's Avatar
My Ride: '08 535i Sport
Is it a 535? I had that happen when I had a loss of vacuum pressure.
Old 05-02-2013, 02:08 PM
///M-Power's Avatar
it's a 05 530i brotha
Old 05-02-2013, 02:09 PM
///M-Power's Avatar
thanks for the reply brotha how do I check that and also should I check it while it's doing this ?
Old 05-02-2013, 02:12 PM
///M-Power's Avatar
Yea this happens around 35-40 mph brotha how can I check that the transmission pan was replaced recently cause I have the transmission slam but he didnt not replace the mecha tronic sleeve
Old 05-02-2013, 03:53 PM
Ducmaniak's Avatar
https://5series.net/forums/diy-do-yo...ctions-108097/
Before you start the car, do what it states in ^ post. Then start the car. Keep in mind when you turn it off, it goes back to lock.
Old 05-07-2013, 11:33 AM
///M-Power's Avatar
anyone else have this problem I don't really want to mess with the hidden menu it's too complicated by just even looking at it really need some help
Old 05-07-2013, 03:39 PM
champaign777's Avatar
My Ride: 2010 550i M Sport
read this link
you have M54 engine
CCV Replacement FYI - M54
Quick Reply: Need Some Urgent Help
