Need some help with retrofit from xenon
My Ride: BMW E60 LCI
Hello guys as the title say im doing a retrofit from LCI halogen to LCI bixenon i follow a DIY from MORI3L very good one an easy one by the way;but looks like or i did something wrong ( i have checked like 20 times cant see nothing different from the DIY ) or maybe i still need to change something with NCS no idea thats why i need your help guys...
I added $522 to the VO and i Flash to pass with bi-xenons instead of halogens! BI_XENON_BEI_LH
aktiv
The problem is that angel eyes dont work or work when they want ( HID Kit installed on the AE ) so my lo-beams works but when i star the car nothing works anymore they start flash and if i stop the motor put the key out,put the key in (i dont start the car) then i push start the lo-beam works also level works what should i do guys i need the car tomorrow night...Left high beam works not right!
I also got the LM2 together with the headlights should i try with this one?mine is also LM2
Ahh my welkome lights dont work neither (indicators and eyebrow works always)
Thank you guys!
aktiv
Thank you guys!
To any moderator this post can be closed problem is being solved!even if i did'nt got any answer thanks anyway and this is a great BMW forum!
Vman33
03-14-2022 04:43 AM
jcolley
08-01-2016 06:48 AM
bestofthebest
03-28-2016 02:47 PM
umnitza
09-02-2015 11:28 AM
