Need some engine codes
My Ride: E60 2006 525d Steptronic, Carbon Black, M Sport-Package, Style 135M Rims, Beige Interior, Dark Poplar Wood Trim, Comfort Seats, Professional Navigation with BMW Online and BMW Assist, HUD, Logic7, TV, Bluetooth, Speech Control, Active Steering, Adaptive Bi-Xenon, 6-Disc Changer, Heated Seats (front and back), Extended Climate, PDC, Sunroof, Auto-Dim. Int + Folding Exterior Mirrors, Electric Rear- and Side Blinds, Foldable rear seats, Electric Adjustable Steering Wheel
Hi,
I'm currently working on the german wikipedia article about the BMW E60. The information page of e60.net is quite nice as a reference, but two engines are missing.
I need the engine codes (such as M54B22) of the following two engines:
520i, 4 cylinders, 1995 cm?, 125 kW (170 HP) @ 6.700 min, 210 Nm @ 4.250 min, which is being built since 09/2007
523i, 6 cylinders, 2497 cm?, 140 kW (190 HP) @ 6.300 min, 235 Nm @ 3.500 min, has been built from 2007 to 2007
Would be nice if you could help me
Thanks in advance,
sese
Thanks in advance,
sese
Originally Posted by a2e60' post='555465' date='Apr 3 2008, 06:06 PM
My guess would be N46B20C (from the 120 & 320) and N52B25BE maybe BF.
Gareth
Gareth
My Ride: '05 530i/6
I would think the last letter differentiates the engines based on small changes that can be seen easiest in hp ratings: e.g. the 118 uses the N46B20B and has 127 hp, where the 318 used the A and had a bit more hp. The 520 is listed as 170hp, so that would indicate yet another iteration as the C only had 148 in the 120i. I haven't looked into the detailed differences in the engines to know what to attribute the hp changes to.
Gareth
Gareth
Gareth
Gareth
Do you also know the engine code of the E90/E92 M3 with 420 HP?
Originally Posted by a2e60' post='555755' date='Apr 4 2008, 02:13 AM
S65B40 if wikipedia is correct
If I only knew what a S65B40 _felt_ like....
Gareth
Gareth
thesalboy
04-08-2015 09:13 AM
