Need Help w/ 166 rims...
My Ride: 08 535i
Black
![Smile](https://5series.net/forums/images/icons/icon7.gif)
So here is the problem. I found some M5 166 rims for 850! well they are in great condition and running 245/35/19 up front and 265/30/19 rear. This is on an 2008 535i non sport. They bolted up fine. However, when i decided to do an op check, the car wouldnt move! after an inspection, i noticed the rim was jammed into the strut! What gives? Do i need spacers in the front?? I know of the rears using 12mm spacers, but purely cosmetic. As far as front, i never heard of them needing a spacer....ANY help please????
My Ride: 08 535i
Black
Originally Posted by BigMike' post='826059' date='Mar 25 2009, 02:26 AM
Are you sure they're REAL BMW M5 rims?
If they are OEM M5 166 rims, they don't need spacers nor will they rub if the tire specs are right.. Mine are 235/30/19 and 265/35/19.
My Ride: 05 545/6
Originally Posted by dp2008' post='826311' date='Mar 25 2009, 12:12 PM
yes as far as i can tell...
My Ride: 08 535i
Black
Posting pics in a few
Correction, its running a 235/35/19 up front...and for 300 bucks?? LOL ill switch back to the stocks if i cant make them work. Any ideas??
My Ride: 1985 325e (sold it in 1996) // 2001 Z3 2.5 / White / Blk Lthr / 5-spd (wife's) // 04 530i / Metallic Blk / Beige Lthr / 6-spd / Logic7 / 19" 166 Michelin Pilot Sp
+1 sounds like a screw job. That's gotta suck.
Bona-fide 166s should fit like gloves.
My Ride: 2008 550i sport
This will not help your problem by any means, but there is one thing I've learned quickly concerning wheels in this forum is that 1) confirm your offset requirements 2) If the deal is too good to be true, it probably is. 3) run it past a shop like trinity to confirm.
I hope you find resolution to your problem quickly man. I just had to unload a sweet set of 124's cause the offset was for RWD E60!
My Ride: 2004 545i Sport loaded
Damn.. I'd have picked em up if the price was right. I can use a spare set for when these crack, plus I have some minor roadrash on one (bought it that way)..
