need help reading INPA screenshot
Old Aug 26, 2013 | 09:43 AM
mtler's Avatar
My Ride: 528xi, premium, navi
Model Year: 2010
Engine: N52
Exclamation need help reading INPA screenshot
Hi folks,
as I started the car ('06 530xi N52 engine) this morning, I felt the engine misfire. Couple of seconds later, I had the check engine light come up.
After scanning the car with INPA, here is the screenshot from the memory read screen.
Now I was right as it was a misfire. I can see that it points at cylinder number 2 with the 29CE code.
Can anyone please help me understanding the other lines?
Type of error, readiness flag, error-status?
Can we understand if it`s ignition related or fuel related from the messages?
I was thinking of changing the spark plugs (they are due in 2000kms anyways), and swapping the "faulty" coilpack with another cylinder to see if the problem follows it.
Thanks for your help!
Old Aug 26, 2013 | 02:50 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
I've only been using INPA for a few months, but if I had to guess I'd say you had a one time misfire on cylinder two, it is not consistently misfiring on cylinder two, and not something to worry about. there are several 'faults' that can be stored inside the ECU that won't necessarily illuminate the check engine light. That's what I take away from that screen shot.
Unless you're having a consistent MIL and misfire codes for cylinder two I wouldn't worry about it. Perfectly healthy engines are capable of random misfires.
Old Aug 26, 2013 | 03:43 PM
pcy's Avatar
pcy
This is same as seeing 'pending codes' with generic OBD-II code reader.
Very likely, the ignition coil on cyl 2 is misbehaving and it will eventually get worse. If I were you, I'd just swap ignition coil on cyl 2 with some other ones and monitor.
Old Aug 26, 2013 | 04:04 PM
tonyb635's Avatar
I would do just as you suggested. I had a misfire and INPA didn't show anything. After a few weeks of it the CE finally illuminated. I was at the mileage for plug replacement so installed new plugs and swapped number 6 with 5 coil pack and problem was gone. Not sure what the other info is telling you though.
Old Aug 26, 2013 | 06:58 PM
mtler's Avatar
Model Year: 2010
Engine: N52
Thanks for your feedback guys!
I swapped coilpack #2 with #1 and as suspected, the problem moved to cylinder #1!
I even listened to the injector "tick" with a screwdriver to make sure it was opening/closing.
I will be purchasing a new coilpack tomorrow and replacing the faulty unit.
PS I replaced all spark plugs while I was at it.
Thanks for your help decoding my screenshot!
Cheers
spitfire23
May 12, 2015 04:23 AM
rizwan1377
Apr 5, 2015 05:22 PM
Stranger12
Apr 5, 2015 10:42 AM
lc holmfirth
Mar 22, 2015 10:28 AM
jonboy
Mar 20, 2004 07:38 AM
