Need help narrowing down codes for crank no start
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
You can't mix and match the series. Different modules to communicate with for the most part and you don't know if they share the same p/n. You need to get into E60 to fix your issues. At this point if you can't get INPA to work correctly you're just spinning your wheels.
My Ride: 2004 545i bmw 160xxx, base model
Model Year: 05 530i
Engine: 3.0 M54
If your INPA can communicate with all the other modules and not that one then it's a dead module. I'm not going to say that's what it is because I'm not looking at you INPA to say if you're missing files or configuration is incorrect. What version SP-DATEN are you using?
Model Year: 05 530i
Engine: 3.0 M54
You either have missing files, connection configuration is wrong or bad cable. I don't know how else to assist you. I've been using BMW software and coding tools for over 15 years and have seen it all. Maybe someone else can chime in and help you.
