Need help narrowing down codes for crank no start
My Ride: 2004 545i bmw 160xxx, base model
Need help narrowing down crank, no start issue for a 2004 545i automatic 160xxx replaced motor with another used motor, ran INPA and here are the codes as follows
sim/sgm 93fc 20
Stvr/tebf 9b8a 20
Dme/dde 2737 68
278a c4
27a4 04
Afs 6140 30
614a 70
Ce93 70
Ars/svt 5d60 e4
Dsc d369 e4
5f48 e0
Sine 9d12 1
KOMBI 931b 64
Mostgw e18c 20
E18f 20
Lm e519 68
Klima 9c54 64
9c55 61
Sbsr 95b8 60
… battery was going dead while codes were pulled, couldn’t access battery charger at the time but will try again later today if it helps, was under the impression dme and ews needed to be synced, tried to “reset sync” and it brought up a “ifh-0009 no response from control unit api job error or no such result ! Continue script processing?” And if I clicked yes the window doesn’t go away if I click no it goes back to previous diagnostics menu in INPA after selecting functional jobs/engine ->n62 for e60
sim/sgm 93fc 20
Stvr/tebf 9b8a 20
Dme/dde 2737 68
278a c4
27a4 04
Afs 6140 30
614a 70
Ce93 70
Ars/svt 5d60 e4
Dsc d369 e4
5f48 e0
Sine 9d12 1
KOMBI 931b 64
Mostgw e18c 20
E18f 20
Lm e519 68
Klima 9c54 64
9c55 61
Sbsr 95b8 60
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Didn't you get that error in INPA. If so, you need to fix the issue so you can talk to the car. Either your interface is configured incorrectly or your INPA is not complete. Double check you cable also to ensure pins 7 & 8 are jumped
Model Year: 05 530i
Engine: 3.0 M54
Does your cable have a selector on it either button or switch? If so click or slide it then try. Do you know if your INPA was installed correctly? Has it worked prior to with communicating with the modules other than reading codes
Model Year: 05 530i
Engine: 3.0 M54
If the cable doesnt work correctly no matter what the selection is then your INPA is not installed correctly. Need to check connection settings in device manager and ensure the driver has been loaded
