Need help - fluid leak
Old 01-21-2013 | 01:14 PM
mirage21's Avatar
My Ride: 2006 530i Alpine White , Premium Package, Build Date 07/05. BBBB-BONE STOCK
Default Need help - fluid leak
2006 530i
I have some fluid leak/spray around the oil filter and air filter area. It's sprayed on the top of my air filter housing. I can't tell if it's oil or coolant. I had to top off 1 quart of oil last week (due to low oil level), then cap off my low coolant (message this morning).
Only thing I can see is possibly a hose that appears somewhat wet, cracked. Is this hose DIY? Also notice a pool of oil but don't know if it is related. Belts and alternator appear to be clean of leaking fluid/spray; however, the bottom floorpan is dirty.
Thanks,
Attached Thumbnails Need help - fluid leak-1.jpg   Need help - fluid leak-2.jpg   Need help - fluid leak-3.jpg
Old 01-21-2013 | 02:06 PM
BimmerFan52's Avatar
Oil filter housing gasket is a pretty common failure point on the 6 cylinder engine.
Old 01-21-2013 | 02:21 PM
Original's Avatar
My Ride: 2010 535i M sport
Model Year: 535i / 2010
Probably using aftermarket oil filter.
Two times that I do not used OEM oil filter got exactly what you're having.
After market oil filter o-ring is thin and last less.
Old 01-21-2013 | 03:11 PM
mirage21's Avatar
I've used an OEM oil filter. I can't recall if the o-ring was new or if it came with the OEM filter.
Old 01-21-2013 | 04:34 PM
pcy's Avatar
pcy
Oil filter cap leak is different from oil filter housing gasket leak. It should be easy to figure out which one is leaking just by looking at the oil filter cap and look for the source of the leak.
Old 01-21-2013 | 05:13 PM
JJw's Avatar
JJw
My Ride: 08 AW M5 94 AW 540i
could be oil cooler gasket leak
Stuboski
11-05-2021 06:58 AM
PakiBeamer
12-09-2016 04:40 AM
subieworx
09-21-2015 01:19 PM
ST JAMES
09-04-2015 04:54 PM
Bounce
08-31-2015 10:04 AM
Quick Reply: Need help - fluid leak
