need help choosing wheels
My Ride: E60
Hello! Can you guys help me choose rim and tire? My car is 2006 530i sport in titanium grey color. I'm planning to go size 19 staggered and dont want to drop the car. I would like to keep same suspension and got to be something that does not exposed too much inside fender. What is the right offsets? My budget is no more than $2,000. Thanks a lot.
$2K for wheels & tires or just wheels?
Being that this topic is discussed more than any other on this forum, you can find a crapload of info just by using the search function above. However, some basic info for ya:
Front wheel is typically 8.5" with ET12 to ET18 being the norm, with 245/35/19 tires.
Rear wheel is typically 9.5" with ET17 to ET32 being the norm, but the closer you can get to ET17 the better the push outward in the rear....with 275/30/19 or 285/30/19. If you use a 285 tire, you will need closer to ET20-22 in the rear.
Depending on your tire & wheel widths, your offsets may need to be adjusted...
Since you are going 19", I'd say go with OEM rims...either 128, 172, 166 or 167 (a bit outside your price-range).
My Ride: 2004 (7/04) 545i 6-Spd Manual Metallic Silver Gray with Gray Interior
Premium Pkg, Premium Sound, Sport Pkg, Cold Weather, Active Steering, Navigation, Rear Sunshades, Folding Rear Seats, Rear Side Shades, Logic 7, Comfort Seats, Rear Heated Seats, HUD, Rear Side Airbags, PDC, Bluetooth Retrofit
Exterior: Venture Clear Bra, Bright Angel Eyes, Euro Reflectors, Blackened Grill, VMR 713 19" Staggered with General UHPs, 13% tint rear windows
Engine: K&N Air Filter, Deleted Carbon Filter , RPI Scoop, RPI Exhaust
Go with VMR , or miro blacks
+1 with the above posts....avoid a 19" wheel with a lip..as that might make the wheel look smaller than it is...
My Ride: 2004 545i, 1995 M3
BP
