Need help asap
Whats up guys few weeks ago my sunroof was leaking i changed the seal and put in a new one today i got a message with pass restrain system and then after at night it started to rain i got this message saying Electrical System Malfunction Continued Driving not Possible i read online and people said it from the sunroof but when i opened it the seal was wet from inside im also driving with my rear bumper off cause i got rear ended any help would be appreciate it
Check you passenger floor for wetness.... if wet, pull it all up and dry it our thoroughly.
Originally Posted by jaycal3
(Post 1480570)
Recalls Summary | Safercar.gov | NHTSA |
Originally Posted by ///M-Power
(Post 1480599)
thanks for the reply bro i checked nothing wet i checked under spare tire nothing leaking i tested my sunroof seal i wet it with hose for 5 mins no leak nothing the message is not on anymore but the pass restrain is on still i heard there is a recall for it
Originally Posted by louisrai
(Post 1480602)
what Jaycal3 means is to check your fuse box under passenger seat, did you?
(Post 1480602)
(Post 1480618)
I actually meant the carpeting... many modules and sensors are under the passenger side carpet. Glad its not wet.
You'll have to clear an SRS error, it will not disappear by itself.
