NEED HELP!!!!!!!!
My Ride: 2004 Blacked out 530i, Carbon Fiber Pillars, Carbon Fiber Emblems (Wheels, Steering Wheel and Hood/Trunk). Blacked out kidney Grill, Smoked side marker lights, 15mm Rear Spacers, K&N Filter, Window Tint, Navigon Syst. Breyton Front Lip. Bilistein Coil Over Suspension Front & Rear Droped 1.5" Genuine M5 Pedal set. Mtechnik side skirts, RPI Exhaust.
Can some please tell me how to install the plate bulbs and how to remove the interior front dome light cover?
take a flathead screwdriver for both and find the indent on the edges of both and push in and down, they will pop off. The license bulb is on the left. Push towards the right and down. The interior dome you push in on the front and down, very easy should pop right off
Wow this is an old thread, the only one I could find on the subject.
Did my interior bulbs without any problem but I am having trouble removing the license plate bulb housing.
Anybody got any tricks or ideas?
My Ride: 2004 530i
each license plate bulb is housed around plastic .. on each plastic piece there is a place to put a screwdriver head. put the screwdriver head in that slot and slide the plastic to the right ( if not right, left ). it is spring loaded so it pops out and then you'll see how to switch the bulb. very easy mod.
each license plate bulb is housed around plastic .. on each plastic piece there is a place to put a screwdriver head. put the screwdriver head in that slot and slide the plastic to the right ( if not right, left ). it is spring loaded so it pops out and then you'll see how to switch the bulb. very easy mod. ![Twoup](https://5series.net/forums/images/smilies/imported/twoup.gif)
I'll try pushing them
My Ride: 2004 530i
