5Series.net - Forums
-   -   NEED HELP! (https://5series.net/forums/e60-discussion-2/need-help-58901/)
tonymac Jul 25, 2008 03:27 AM
My check engine light just came on. I turned the car off and turned it back on to see if there was small glitch or something... Nothing... Still on. I turned it off for about 4 hours and when I came back, still on...
My iDrive tells me that everything is ok. Engine oil, brakes, oil level, even the system check says its ok...
Has anyone experienced this? Oh, I do have 3,000 miles left before I change the oil. Do you think that's it? But my iDrive did not alert me at all.
Please help before I get ripped off at the dealer.
Tonymac
Rudy Jul 25, 2008 03:34 AM
Is your gas cap secured properly?
tonymac Jul 25, 2008 03:44 AM
Serious? Let me go and check.... BRB
Tonymac
tonymac Jul 25, 2008 03:53 AM
Well, I think it was... I didnt see anything wrong. I took it off like normal and put it back on turned until it clicked and it is still on...
Tonymac
Rudy Jul 25, 2008 03:55 AM
Tonymac
Well that's always the first thing to check...
If it were loose or not sealed properly, the light will come on -- once the cap is secured, the light doesn't always go off immediately. It can take a while for it to go back out.
If it's anything else, you might need the dealer to connect to the car and download whatever fault is stored in memory.
tonymac Jul 25, 2008 03:56 AM
Much obliged sir... I appreciate it. I will let you know if the light goes out then.
Tonymac
Get One Jul 25, 2008 04:38 AM
does it have the emissions fault warning at all?
tonymac Jul 25, 2008 04:46 AM
Nope... Nothing else is on. And the iDrive says everything is fine...
Tonymac
Martin525i Jul 25, 2008 04:48 AM
Check engine can come on for faulty o2 sensor or other emission related stuff. If was a glitch or gas cap you can unplug the battery for a few minutes and it should clear itself. However, if it comes back on it is dealer time or take ot to a place that cane read obd II codes.
Martin
rsyed Jul 25, 2008 04:50 AM
What car do you have? diesel? petrol? lci?
