Need Help!!!
after i using CIP v26 to complete vehicle encoding, my radio, cd changer, and audio become cannot function. It show communication to CCC error. did any1 having this same problem as mine? or any1 have any suggestion?
Also, CIP is a term that has not been in use since CIP 19. After that, it is Progman as in Progman 27.
Originally Posted by JSpira' post='489261' date='Nov 2 2007, 09:19 PM
I would guess the CCC might be fried (happens in very rare cases after a Progman update) but perhaps you should explain how you updated the car yourself to begin with.
My Ride: MY2005 E60 525i M Sports
Where are you located? i've had similar experiences where in my country, they bring in reconditioned cars (used) from japan and like your situation, it can only detect radio frequency of up to 90.0 mhz...to tell you the truth, if the car is a japan spec, you'll have to encode the car with a japan progman of your desired version (e.g. progman v26, v26.2, v27.0 etc.)...progman update for an eu spec is not compatible and will fry the ccc (as said by jspira)...the funny thing about progman updating is that even though a japan spec bmw is categorised as an eu spec car, the whole system of the i-drive is different...it uses special ccc for japan (whereas it offers md/cd as standard and the dvd or hdd for navigation in the rear boot)...even the tcu for telephone doesn't support bluetooth and the navigation system cannot read dvd maps for other countries except for japan due to the different system offered...(ours is navteq based dvd maps if i'm not mistaken).....
So, to answer your question on the radio frequency adjustment to suit your country with the existing ccc on the car, it is definately impossible...
you can't change the frequency range unless you change the antenna module (but not by encoding via progman)...fyi, the antenna has to be pre-programmed on an eu spec car first and swapped straight without encoding...this is the only way it can be done, but it will not function perfectly...in manual search mode, you can see the rds of your prefered station, but the frequency will only show up to 90.0...it's as if you've tricked the ccc...but in "memorised station" and "all station" it will show properly with/without rds activated.....
hope you understood my explanation...
He has not, as of yet, explained how he is updating Progman himself.
