Need Help!!!! 2006 BMW 530XI
My Ride: Bmw 530xi
I have a 2006 BMW 530XI. The serpentine belt ripped and some pieces got stuck inside the engine. I took it out and I reset the timing. After doing so, the car would only crank and not start. So then I replaced both camshaft and crank sensors. Again, it cranks and no start. Then I checked the car if it is getting spark and it's not. I need help please!!!!!!
My Ride: Bmw 530xi
115,000 miles, the codes are
2A31- valvetronic eccentric shaft sensor
2CF9- throttle valve potentiometer 1
2A47- Valvetronic eccentric shaft sensor plausibility
2D09- Throttle
But these codes are because the car isn't running. I did a test and found out that the car is not getting spark and that's my problem right now. Any suggestions would be good.
todg76
09-03-2013 08:06 AM
