5Series.net - Forums
-   -   need help (https://5series.net/forums/e60-discussion-2/need-help-146282/)
watda Dec 30, 2016 07:02 PM
need help
im new to this forum and hope someone can help me out. i just replaced both valve cover gaskets along with new spark plugs and coils. good thing is no more leaks, bad thing is now the is not running right. rough idle, no power and vibrates. i havent been able to figure it out .:(
i have black 07 550i with 85k miles.
H F Jan 2, 2017 02:43 AM
Welcome to the forum ..
Iwould suggest that you go back and double check all the connector plugs on all the cam sensors are pushed all the way in , essentric shaft sensors . make sure the spark plug boots are fitted correctly and that all the coils are snapped on right . Make sure the maf sensor is connected properly .. Then check for vacume leaks and a cracked vacume hose ..
Hopefully its something you missed .. But If everything checks out good ,, there is a possibility that you broke the essentric shaft sensor . its really easy to do if you're not careful putting the covers on and off .
watda Jan 2, 2017 01:12 PM
ok, thanks. i hope its something simple.
