Need help!
Old 08-26-2014 | 11:42 AM
khmer545i's Avatar
My Ride: 05 545i
Default Need help!
My 05 545i is acting up big time! The car start and the rpm goes up and down. At one point it drives than completely shut down, not quite sure what it is... from reading through online and forums. I'm guessing these factors: Throttle body sensor, cam and/or Crank sensor? Please help took it to a local mechanic and they have no clue.
Old 08-26-2014 | 12:34 PM
H F's Avatar
H F
My Ride: 2005 545
Get a BMWhat app with a wifi dongle . Get some codes to give you a direction to point to . It's really hard to guess and give you a significant answer . Due to so many things that it could be . Like a MAF ,Disa Valve, CCV valve, a vacume leak , secondary air hose under the manifold . All those will give you a rough idle . But since you said the car shut off , my guess would be the MAF .
Old 08-26-2014 | 01:10 PM
E60I's Avatar
My Ride: 2006 BMW 530I
Model Year: 530i
From personal experience, a bad ignition coil can also do that.
Old 08-26-2014 | 07:52 PM
khmer545i's Avatar
My Ride: 05 545i
That's what I though as well...after cleaning out the throttle body it runs a little better. The RPM doesnt jump up and down as much...Is there a test that i can do?
Old 08-26-2014 | 09:40 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
is the check engine light on? get the codes scanned.
Old 08-27-2014 | 08:35 AM
khmer545i's Avatar
My Ride: 05 545i
no codes at all... I wish there were codes ..
Old 08-27-2014 | 09:03 AM
Amherst's Avatar
My Ride: 07 E60
There are codes set. Guaranteed!
That is why HF suggested the BMWhat app and dongle. They may not show up in I Drive.
Old 08-27-2014 | 10:29 AM
turboawd's Avatar
or just go to local autozone or oreilys. they pull codes for free.
Old 08-27-2014 | 04:26 PM
khmer545i's Avatar
My Ride: 05 545i
Is there a thread on how to this?
Old 08-27-2014 | 04:29 PM
texasmr2's Avatar
My Ride: Stock 2004 BMW 525i
Wink
Originally Posted by turboawd
or just go to local autozone or oreilys. They pull codes for free.
ding ding ding!!!
