Need advise on Software upgrade Result
I've just took my car to a local independent BMW repair shop for the complete software upgrade.
They kept the car overnight as they said my car components never been updated. (About 4-5 page items report after upgrade performed) I glanced through the items got updated, and had green checked marked, however, there were few items with "Red" which upgrade did not success. For example, when Idrive was getting upgraded, there were about 15-20 items but one item was not success. I think the total un-success items were 4-5 items After I got the car back, I really can't tell the difference, however, I have found only one issues that my USB port is not reading any memory cards anymore and AUX has been grayed out and not working. I am going to take the car back to the shop and they are going to work and get this thing resolve, however, I was wondering if I should be concern about the other failure items or this is pretty much normal as all module may not accept the upgrade? The cost was only $150 and I have been taking my car for all maintenance since past years to this shop. They seems like they are sharp guys and knowledgeable about the mechanical part but I am not sure how much they know about software upgrade as they have just started offering that option as of 6 months ago to their customers. Thanks for any advise or comments |
Sounds like the upgrade turned off the USB and AUX, so should be just a simple back on for them. As to you 4-5 items that are red, I guess it would depend on what they are, you didn't list them.
Depends what equipment they used to upgrade. Parts that go through MOST bus will not be upgraded unless they're using an OP(P)S or ICOM and it is BMW equipment. Most likely the modules you're experiencing with failure upgrade are on the MOST bus. As far as the AUX/USB goes it depends because you didn't list the car you have. Was it a retrofitted item or factory?
Originally Posted by AchtungE60
(Post 1481647)
Yes for an 08 the USB/AUX are factory but is that all you want to share? Anyway take it back looks like the MOST bus failed to program these items into your CCC or they did not do a "complete encoding" afterward
(Post 1481796)
Here is the information I got maybe that more sense to you guys: The ISTA/P version 48.2.002 There was one item with X, SZM, with result/ fault code: "Global Vehicle Communications. CoAPI.2081- Authentication error, type Syc, with part number prog.ECU old: 9169521 and part number prog.ECU new 9183233 Also, one warning on "Initializing rear power window regulator" Here is the last page summary: It will show the ULF-SBX replaced successfully Update integration level successful Vehicle order alignment, successful The Following control module have not responded or responded incorrectly: SZM, The programming status is 12. The control module could not be identify X Concluding work order: 1- SZM (Program P) 2- SZM (Code C) 3- (Initializing rear power window regulator) 4- After completion of programming/ encoding, pair the mobile phone in accordance with the operating instruction Any suggestion as according to the techs that is not a very major things? |
| All times are GMT -8. The time now is 10:26 PM. |
