NCS Expert - Vin Is Faulty
Hey guys,
I'm trying to program Aux into 2005 525i using the coding cable using this video: Thanks |
google will be your best friend. i made that video. if both block dots are shaded in inpa and vin faulty shows up, need to update daten files. no need to use revtors, use expertmode and look on google how to enable it to upload .man files.
Yeah, everythings updated. I used your method. Ediabas 6.4.7, v45.2 daten files and bmw standard tools 2.11. Everythings updated. The anwers im finding for vin is faulty error is that they are all using windows 7/10 and getting the error, but I'm using windows xp on my laptop and im still getting VIN is faulty. COAPI-2000: EDIABAS or SGBD error. IFH-0018: Initalizing failure of the interface handler.
If u have Teamviewer i can set everything up for u.
"If u have Teamviewer i can set everything up for u."
Bump..! @Kewill0360, would you be open to setting this up for me? I am basically at the same point sour562 was. Also, I have an 06 530xi. All Im really trying to do is code an aux for the bluetooth module I put in! M |
Originally Posted by Kewill0360
(Post 1577714)
Matt |
Help setting up
[QUOTE=mattlittlegym;1597724]"If u have Teamviewer i can set everything up for u."
Do you think you could help me set up everything? I keep getting "VIN is faulty" error and I've tried everything. |
