NCS EXPERT Issue
My Ride: 07 530i & 88 325
I've been looking for some help on this on the forum but not able to see anything that matches or that has working links. So wanted to see if anyone has any help with this.
I recently purchased my AUX cable and installed it. My INPA software works fine but when I go to the profile Expert Mode in NCS- Expert if gives me a german error code "ncs expert "profil version 2.0 ungültig"
Hopefully someone can give me a link to something or some help
My Ride: 2009 528xi
Model Year: 2009
My Ride: e61 / KW V3 / JB4 / M5 Rear Sway / FDL Coded / SAT Retrofit w GKE flash / ER FMIC / BMS DCI
Model Year: 2010
Engine: N54
BMW Coding Forum
Try this forum...?
Try this forum...?
I just had to help a friend through this same issue. It's almost certainly a mismatch between the NCS Expert version and the profile version you're attempting to use. You may need to search the web for a new set of profiles (try using Revtor's Expert Mode profile). If you can't find anything, PM me and I can try to send you the profile that I use.
Thanks to GTYellowJacket for sending me the Revtors Profile. I am now able to load that profile with no more issues. Now lastly to get Expertmode working. I have Expert Man profile that works but of all the profiles that I have on my NCS Expert Mode is the only one that will not load.
My Ride: 2009 528xi
Model Year: 2009
DIY: Setup BMW Standard Tools 2.12 on Windows XP > 10
I believe this is where I found everything needed.
So I downloaded the NCS Expert Profiles from this site and I still got the same error. Is there something I am missing when it comes to incompatibility. Since all other profiles work besides Expert Mode. Let me ask this, what is the difference between Expert Mode and Expert Man ?
Model Year: 2010
Engine: N54
Ragtop Steve
FO7 Gran Turismo Discussion
12-07-2015 08:20 AM
Chris Karolenko
10-26-2015 12:56 PM
