Navigation not starting
Old 06-15-2009, 11:18 AM
VW2545i's Avatar
I've searched and found nothing similar. Noticed friday that the navigation is not moving and GPS is not tracking the car. It knows when the car is turned on but then does not change to reflect my location. I loaded a burned nav DVD about 2 weeks ago and had not issues. But now the system seems to be stuck. Is there a way to 'reboot' the system?
Sea n
Old 06-15-2009, 11:28 AM
Rislar's Avatar
Hi bud, on mine i press mute and both ejects on the DVD and CD player at the same time and that resets the idrive
Old 06-15-2009, 12:11 PM
Brit_in_NJ's Avatar
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather. Mods: Carbon filter removed. M5 iDrive knob. Umnitza license plate LEDs. MP3 40% 3M tint ACS Anti-Roll(sway) bars RPI Scoop G-tech Pro RR CF Roundels CF Wheel caps
That's the e60 equivalent of the microsoft 3 finger salute
You could try starting up with no disc and then insert it after you get the notice that no disc in installed.
Old 06-15-2009, 02:38 PM
v_therussian's Avatar
You may have tried this already, but try to just eject the nav dvd and put it back in - works on mine
Otherwise, you might just wanna burn a diff dvd - try another version or smth - sometimes its finicky like that...
Old 06-15-2009, 05:36 PM
VW2545i's Avatar
I've ejected gone back to the old disc but the map still shows the same location and won't move. I'll play with it some more in the morning. So annoying!!!
Old 06-15-2009, 06:10 PM
theXman's Avatar
My Ride: 2004 530i
That might be the equivalent of the blue screen of death from MS Windows.
Sorry to hear that Sean. Maybe you need a hard reset, try disconnect the battery, reconnect it and then reboot.
Old 06-16-2009, 08:52 AM
VW2545i's Avatar
Yeah I may have to do that. It's just stuck showing me the parking lot for my office (that's depressing enough :-P ). I'll try the battery and see what that does. Does anyone know if the antenna for the GPS has any know issues? Just trying to rule out the hardware.
Old 06-16-2009, 10:17 AM
545felix's Avatar
My Ride: 05 545/6
it's got to be more than the antenna- if your car can't get a signal, it uses a built-in gyroscope and your speed to approximate your travel until it can get info from the satellites again. this can leave you completely off course, but moving when the car does. if your map isn't moving at all, something is definitely wrong, and it's more than the antenna.
Old 06-16-2009, 10:28 AM
VW2545i's Avatar
So that takes me back to software then since no changes were made to the hardware.
Old 06-16-2009, 11:24 AM
545felix's Avatar
My Ride: 05 545/6
did you try the three finger salute described above? i think you have to press the power button as well as the two eject buttons.
Quick Reply: Navigation not starting
