Navigation fault code help please
My Ride: E60 2006 sedan auto
I’m still trying to get my navigation system working in my E60 2004
I found some fault codes in the navigation system
The main was was
A3EC no wheel speed sensor
My cruise control is working fine and no dash fault lights are on
Has anyone had an experience with this code and how to fix it?
Thanks
The main was was
Thanks
Engine: N54
The main was was
Thanks
The main was was
Thanks
That’s the problem
The speed sensors are working and so I was hoping the code may give an indication to a separate problem
Like many BMW codes it doesn’t always say the location of a fault
So I do know now that the sensors are working but no signal is getting to the gps uni in the boot
So a long task will be required to trace wires from the rear and more than likely find a broken wire in the loom somewhere
