Navigation can't keep up?
I was on my way from NJ to flushing, NY and the Oem Navigation would not tell me of the upcoming fork in the highway until after I was on the ramp. More noticeable at highway speed. Anyone else notice this type of thing with theirs? I'm wondering if there is any software upgrade. Audi Nav is very good at telling you, "in 1/4 mi stay right at the fork", or "bear right onto rte 678", etc.
Thanks.
Thanks.
My Ride: F11 -14
Sorry to say, but Yes, I've noticed the same. It doesn't happen all the time, and only at certain places so maybe it has to do with how the nav parameters have been programmed? It's a real nuisance, though.
And I'm running on the latest software, so there's no remedy there...
Anyone with more detailed knowledge of the SatNav...?
Location: Europe, Netherlands, Near the (German) Autobahn
My Ride: 525d E60
Depending on the car's history (different tyres, reset, driving without nav-dvd for a while etc) you may want to reset it. Or recalibrate as it's sometimes called. This makes the car find out where it is from scratch rather than with old parameters in memory.
not sure where it's done: was it in the hidden menu (press i-drive 15sec, 3xright, 3xleft, 1 right, 1left, 1 right, press) or in the normal menu or both?
My Ride: 2008 535i, 6spd mtx, Monaco Blue w/Beige interior. Sport, Preimum, Logic 7/HD/I-Pod/USB, Nav sys, rear sunshade, HUD, PDC, Split seats,
Hidden menu... Do tell more about it!!
My Ride: 525d E60
check the forum (search)
when i-drive is in nothing mode (the base screen with the i in the middle and the four arrows)
and then have a look around. Not much to do here but I seem to remember that there was a reset thing for the GPS.
will check later and let you know.
I'm on my second E60 with nav, and the 08's nav is really problematic compared to my 04's (which I had no problems with).
From the day I picked up the car in Munich, the system seems to be 50 - 100 feet off. I'm often sitting at a stop light where the nav system wants me to turn, and yet it tells me that the turn is 50 or 100 feet away. I've also had problems driving on a road with a very close-by parellel road, and the nav system thinks I'm on the parellel road.
Are these the sort of problems that you other guys are experiencing?
btw, I never had any of these issues with the 04, and my dealer tells me there's nothing wrong with the 08.
My Ride: E90 M3
Model Year: 2011
I have found the 550i's satnav to give sufficient warning (did you know this varies by country due to various parameters).
The Audi A8 L I had was pretty good also but no better or worse.
The Infinitis I drove were iffy and the Onstar downloadable directions in the CTS didn't always give enough notice or incessantly repeated themselves.
my nav has probably not been able to keep up on maybe 1 or 2 occasions during the past 2.5 years. chauk it up to a glitch. mine is fine for the most part. hopefully this isn't the norm for you.
