Hi
After having retrofitted the navi pro some months back, and getting over the first exitement about the fact that it actually worked :twoup: I have started to get annoyed about how slow the system is. I started wondering if the part of the reason is due to me using a DVD back-up and not the factory disc. Also, yesterday I was playing around with the Voice Control, and found that using voice input to select the destination did not work - after I got to the point where I should speak the country or street, the system responded "Function not available at the moment".... Today I was in another e60 with navi pro, that was using the factory oem DVD - I tried the voice input (which the owner was not aware you could do :rolleyes: ) and it worked perfect. Also, browsing through the list of street names etc was much faster - as well as calculating routes was also faster. As it turned out, he had a spare oem DVD, but a 2004-2 version. I borrowed it, and inserted it into the DVD drive of my car. It then prompted me to shut down the system and wait 5 minutes. I did, and voila it worked. Now also voice input to select destination. BUT!! After approx 3-4 minutes the i-drive black out and reboots. The back-up DVD I was using before was a 2009-1. And when I fitted the navi pro, the SW was upgraded to the latest version. Does this now make it incompatible with the 2004 rev disc? I will try again with the back-up disc tomorrow to see if the reboot issue is related to the rev - but if you guys have any knowledge, please let me know. I am thinking about buying the latest version of the disc at BMW - is there something about you get a discount if you hand in an older version? Is this a full map: http://cgi.ebay.de/BMW-DVD-Europa-Europe-Business-2009-2-Road-Map-2009-02_W0QQitemZ110437288982QQcmdZViewItemQQptZNavigations_CDs_software_1?hash=item19b6934c16 In that case, it is pretty cheap. Thanks in advance for any help. /Thomas. |
Ok - changed back to the backup 2009-1 DVD. No more resets, but back to slow performance....
I will buy a new disc. The link above is for a Business (I noticed after looking again) - so that's the reason it is so cheap. I found this one: http://cgi.ebay.de/BMW-Navi-DVD-09-2-Road-Map-Europa-Professional-2009-2_W0QQitemZ140355360219QQcmdZViewItemQQptZTechnik_Auto_Hi_Fi_Navigation_Einbau_Navigationssysteme?hash=item20add4d5db Looks like a fair price - but maybe I should wait for 2010-1 - does anybody know when that is available? Thanks, |
you are correct about the dealer discount if you hand in your old disc but the damn discs are still expensive
The 2010 has been available for a short time now. I have a disc for sale.
Late reply - but better late, than never ! :twoup:
With the newest software you can't use the 2004 DVD, the system will restart after 2-5 min all the time. You will have to use a 2009-x or higher! The addressinput with voicerec doesn't work in Denmark, but only on addresses in bigger countries, such as Germany, France etc. I'm using a 2009-1 disc (copy) with speed cameras on it, and I don't have any issues with slow speeds (not slower than OEM disc). I do however have a new problem with my nav PRO now. After 1255 km yesterday from Austria -> CPH, I got the DVD read error message just south of Berlin (when I needed the Nav system at most). The 2009-1 disc was very hot (800 km's driven that day), and had some scratches on it. I burned a new 2010-1 disc yesterday and the Nav system started to work again, BUT the DVD read error appears on the screen after 15-20 min. Have you ever had that problem, or do you have a OEM 2009 disc I can borrow to test my DVD laser reader? :notworthy: |
Originally Posted by E60Sim
(Post 1129343)
With the newest software you can't use the 2004 DVD, the system will restart after 2-5 min all the time. You will have to use a 2009-x or higher! The addressinput with voicerec doesn't work in Denmark, but only on addresses in bigger countries, such as Germany, France etc. I'm using a 2009-1 disc (copy) with speed cameras on it, and I don't have any issues with slow speeds (not slower than OEM disc). I do however have a new problem with my nav PRO now. After 1255 km yesterday from Austria -> CPH, I got the DVD read error message just south of Berlin (when I needed the Nav system at most). The 2009-1 disc was very hot (800 km's driven that day), and had some scratches on it. I burned a new 2010-1 disc yesterday and the Nav system started to work again, BUT the DVD read error appears on the screen after 15-20 min. Have you ever had that problem, or do you have a OEM 2009 disc I can borrow to test my DVD laser reader? :notworthy: I ended up buying the 2010 DVD from Bruce - works like a charm. Only problem being the limited POI (doesn't have the simplest things you would expect). Voice inputs works fine in DK :twoup: You are welcome to try it if you want (as long as your drive does not scratch it :rolleyes: ) PM me if you want to meet. |
Hi Thomas!
My navigation works like a charm again. It burned a 2010-1 disc at a high quality disc at LOW speed, and it works!! I also noticed that voice input works with 2010-1 !! :twoup: :twoup: :twoup: However it's the "small POI" database on this 2010-1 disc, so I'll find a 2009-1 with the large database incl speed cameras! |
(Post 1134530)
Hi Thomas!
| All times are GMT -8. The time now is 06:55 AM. |
