Navagation commands
Old 05-15-2004, 03:56 PM
Tsandas's Avatar
I though when you are getting navagation voice commands that it would either lower or stop the radio or CD while commands are given?
Am I right? Mine does not. The commands are given while the radio is playing and it is ver hard to understand.
Thanks <_<
Old 05-15-2004, 05:10 PM
jksanford's Avatar
I had the same thought when I first started working. Try this: While a command is being given to you, turn up the volume on either the steering wheel or near your radio. You can adjust it while it's talking to you....
Old 05-15-2004, 05:24 PM
Tsandas's Avatar
Will that lower the radio or just rasie the voice commands?
Thanks
Old 05-15-2004, 07:17 PM
Guest_incite23
Guest
Posts: n/a
That is strange mine mutes the Radio/CD while the Voice Command button has been pressed.
Old 05-15-2004, 07:33 PM
Tsandas's Avatar
That is what I thought should happen!
Old 05-16-2004, 10:17 AM
Guest
Guest
Posts: n/a
how do you have the system repeat the last command?
Old 05-16-2004, 11:31 AM
sj3
sj3's Avatar
One of those two buttons on the wheel is programmed for this automatically. Just press it and the last nav instruction is repeated.
Sam
Old 05-16-2004, 02:26 PM
Tsandas's Avatar
Yep, one of the buttons is already programed to do that. I can only set one steering wheel button!
Old 05-17-2004, 12:54 AM
Waschbaerbauch's Avatar
This is a known software bug (at least in germany). The lowering of the radio volume, while the navi gives directions is missing in some cases.
Talk to your dealer - and get a sw update.
cheers,
Stojan
Old 05-17-2004, 11:16 AM
Tsandas's Avatar
Thanks, I have a call into him!
Quick Reply: Navagation commands
