N62B44 (545i) vs. N62B48 (550i)
Does anybody know if there is any particular feature in the 550i V8 to address the water pipe seal degradation problem?
I understand that the improved engine cooling should alleviate the problem somewhat. Anybody aware of something else besides that?
My Ride: 07' BMW 550i
No I didn't hear anything like this, only I know is I asked foramen shop at Sterling BMW VA and he said those engine has been address this issue so it should be a problem even so he saw one or two 7-series (750) with this problem.
My Ride: 2005 545i
My Ride: 2007 BMW 550i Sport Pkg, 6MT
I have 63k miles now and so far I haven't had any engine/coolant related problems yet.
Leak Diagnosis Pump (also called DMTL pump) was replaced at around 47k.
My Ride: Silver 550i: Orion V2 - LCI Tail Lights - VRM 710 (Powder Coated Matt Black) - Magnaflow Cat Back Exhaust - Painted Brake Calipers (Red) - Painted Rear MTEC Kit (Black) - Window Tint (Windshield 70% - All other Windows 55% - Smoked Side Markers
07 550
1. Changed Valve Gasket Covers ($700)
2. Changed Timing Chain Covers (Did it because I was already doing valve covers) ($150)
3. Changed Belt Tension er ($100)
4. Installed a new transmission pan and replaced the Transmission Fluid ($250)
5. Cracked bushing in front lower control arm. Changed the whole front end. ($950)
6. New strut mounts ($200)
7. ST Coilovers ($1200)
8. Rebuild Vacuum Pump ($120)
All this was done @ 60k. I had a horrible engine leak. My valve covers were in pretty bad shape. The Timing chain covers were starting to go bad as well. Glad I changed those while my mechanic was pretty much there. I didn't need the whole front end for my car. I just got a real good deal on the whole Meyle HD kit for my car, and figured what the heck and did it anyway. My bearings on my mounts were bad so I changed them after I had my coils installed. Everything That I have listed has been done in the past 30 days. it has cost me a lot more than I was planning on spending in a month.
My Ride: 2006 bmw e60 550i msport
i have changed rocker cover gaskets, vacuum pump seals waterpump and attatched parts, CCV's, VVT seals, and done the trans service with filter and zf oil and the 6 seals that fail, have xhp stage 3, it gets a hard life skids, drags, and a bit of track time, also change my oil 5000kms
im at 151,000kms, im very pleased with running and operation of myne, more so changing rear tyres alot and just started replacing suspension parts
