n62 water leak??? ACK!!!
My Ride: 2008 550i
Yep, that's the timing chain cover coolant weep hole. I thought the crossover pipe problem only affected 545s, not 550s? Did you get it fixed yet?
My Ride: 2008 550i
How many miles? Was it an early 06, 07, or an LCI (08-10)?
And gotta love German sourced rubber. Another expensive fix caused by a premature component failure worth pennies...
My Ride: 02/2006 525i Titanium Silver Metallic
Manual 6-Speed
Did you replace it with oem or one of those collapsible transfer pipe kits u see online?
Was it a very difficult job other than removing the intake manifold?
Also, have any more pics you can share?
I've just started reading these forums again after about a 2 year break. I remember you very specifically for helping guys out with repairs and always being a huge help to the forums! Thanks!
Just nuts and bolts, attention to detail and common sense.
Yes ill find some of the other pictures and post later...
Thank you for saying that, sometimes these post I put up makes me wonder if it is just wasted air space...
![](https://lh3.googleusercontent.com/-oPoam2LEZ5w/U6wI9pYpGWI/AAAAAAAAprk/vaZJMaE3sMk/w967-h725-no/20140623_125352.jpg)
![](https://lh6.googleusercontent.com/-XnBlX3CQPNs/U6wKwSkrvWI/AAAAAAAAptw/oMvJbjfLFIE/w967-h725-no/20140624_112740.jpg)
![](https://lh6.googleusercontent.com/-bw2fRkjZEKg/U6wK9CBQlkI/AAAAAAAApt8/w1KhOElDQyc/w967-h725-no/20140624_113059.jpg)
![](https://lh5.googleusercontent.com/-9Fg9qEsSC_E/U6wLHN_ljkI/AAAAAAAApuI/lwwTQRDXy2E/w967-h725-no/20140624_171301.jpg)
![](https://lh4.googleusercontent.com/-9NCUcjj_zgE/U6wLOdfjw7I/AAAAAAAApuU/3rnLNakpOtY/w1118-h629-no/20140624_175454.jpg)
![](https://lh6.googleusercontent.com/-fTT-uMhwSaQ/U6wLgQZDk1I/AAAAAAAApus/uiZ70s-Yv6s/w967-h725-no/20140624_175527.jpg)
![](https://lh4.googleusercontent.com/-D2COpfUkk8E/U6wL9-NkOgI/AAAAAAAApvQ/kSPNzFHmfZ0/w544-h725-no/20140624_184135.jpg)
![](https://lh6.googleusercontent.com/-odpR8bccWqk/U6wO7cNoIhI/AAAAAAAApzM/7K3tsJ8HeOo/w544-h725-no/20140625_122141.jpg)
![](https://lh4.googleusercontent.com/-x6gw6ZzZuGc/U6wPFjdzt9I/AAAAAAAApzY/jk7aOJDUp9s/w544-h725-no/20140625_122147.jpg)
And always check the ports to see of anything fell in!!!
I take a picture of the ports I cannot easily see inside. note the intake ferrule that fell inside the port!
![](https://lh3.googleusercontent.com/-ZdbbCc4d3XI/U6wPvoteBkI/AAAAAAAAp0I/JxUmg_8D1YY/w544-h725-no/20140625_131403.jpg)
