N62 V8 Intake manifold
Old 02-12-2013, 05:58 PM
damian's Avatar
My Ride: 545i
Default N62 V8 Intake manifold
does anyone here have a video or DIY on exactly how to pull the intake off an N62 motor? All the videos for the coolant tube underneath the intake start with the intake already off... I haven't taken a close look yet, just wanted to see if anyone here may have a diagram or something similar.
Old 02-12-2013, 06:21 PM
Stephen Max's Avatar
My Ride: 2004 545i Sport 1998 M3
It's pretty straightforward. The hard part is disconnecting the myriad of electrical connectors that run to the vanos solenoids, alternator, temp sensors, cam position sensors, etc. Some of them are hard to get at. But once you get all that done, lift the harness up out of the way, remove the intake air tube and the y-shaped breather tube, disconnect the fuel line from the fuel rail, remove the intake manifold bolts and lift it up and out. And there are probably a couple of other things that need disconnecting and removal as well, but it is all pretty self-evident.
Old 02-12-2013, 06:34 PM
pjinca's Avatar
There are threads with pics in the DIY section.
Old 02-12-2013, 06:54 PM
damian's Avatar
My Ride: 545i
i figured as much on it being straight forward, thanks for the info Stephen. All this BS for a piss poor o ring.
PJ: i have checked through the DIY, and ran a few searches prior to posting this. I may have missed it though, would you happen to have a link?
Old 02-13-2013, 10:18 AM
ck-e60's Avatar
My Ride: 545i - GONE
I wasn't able to remove my entire electrical wiring harness because some lines fed down behind the alternator and to the brake vacuum pump. So what I had to do was shift the harness side to side when removing the fuel rail (which you pull straight up after removing 4 bolts). intake manifold held down by 10 nuts. Easier to put hood in service mode, remove intake, strut bar, cabin filters, cabin filter housings
Old 02-13-2013, 11:33 AM
Yeah, that alternator connection was a real bitch. Now that I think about it, I had to disconnect the power steering metal tube (that runs in front of the engine and does a 90 degree turn next to the alternator) at the PS reservoir and lift it up out of the way so I could get at the alternator connector.
Old 02-14-2013, 08:43 PM
damian's Avatar
My Ride: 545i
sounds like a bit of a PITA... eh no worries, i will consult this thread as i go and take a few photos while im at it... thanks for the helpful input thus far gents
Old 02-15-2013, 12:24 AM
RTR
RTR's Avatar
Here's a DIY for coolant transfer pipe repair on 645i, has lots of details in the pdf.
DIY: Coolant Leak Repair ( Cap w Seal and Expanding Coolant Pipe) w Pics - Bimmerfest - BMW Forums
Good luck!
Old 02-15-2013, 09:48 AM
damian's Avatar
My Ride: 545i
excellent link sir, much appreciated
Old 02-16-2013, 06:44 PM
west's Avatar
The thing we found crazy about pulling off the factory intake manifold was the metal spacers that had been pushed in to the bottom of the intake manifold. We had a couple just fall out! Would have been fun to fish for them if one of them fell in to the cylinder head.
Quick Reply: N62 V8 Intake manifold
