N62 Upper chain cover gasket replacement
#22
My Ride: 2008 550i
Alternator does not need to be removed to change the upper timing gasket. Just loosen the main bolt and remove the other, then tilt the alternator toward the right. That gives you enough clearance to get to the bottom corner bolt.
#25
12 nm or 9 ft-lbs. Tighten bolts till they bottom out then torque down. I didn't have a torque wrench with that very low settings and so I just went by feel (it's my car so I wouldn't recommend you do this) I've been turning wrenches a long time so I'm comfortable doing this
#26
My Ride: 2007 BMW 550i M-Tech
#28
i unscrewed that bracket with a t-25 torx bit and moved the lines out of the way to unscrew the parts
And is it enough room to unscrew it from the bottom of the car? I mean, what is the easiest way?
Thank you for your help!
#29
My Ride: 2008 550i
That is the main reason the bracket is there, to rigidly clamp the loose lines in place so they don't fatigue from constant engine/running vibrations.
#30
@dingolfing, You mentioned "However, the left frame rail is in the way, so you need to jack up the engine". Did you meant to actually lift the engine up? I'm really having hard time to remove oil line brackets to take out the screw.
